Date/Time: Tue, 07 May 2024 15:58:13 +0000
Intraday timeframes won't display; only daily timeframes and higher show
View Count: 1186
[2014-06-23 11:39:35] |
Julian Nazza - Posts: 12 |
Daily charts and higher timeframes display fine, but when I try to change the chart to a smaller [eg. intraday] timeframe, no data is displayed. I have tried everything to resolve this issue. Thank you for your assistance. |
[2014-06-23 12:20:40] |
namlem - Posts: 94 |
You have probably loaded a historical chart. Try to open an Intraday Chart or change it in Chart Settings. Look at the screenshot. |
Attachment Deleted. intraday.PNG / V - Attached On 2014-06-23 12:20:19 UTC - Size: 175.6 KB - 367 views |
[2014-06-23 13:03:41] |
I've tried that before, and it didn't work. I also tried to load an intraday chart by using the "Find Symbol" menu, and it still did not work. No data and no value axes show in the chart. Daily timeframes and higher display fine. What shall I try next? Thanks.
[2014-06-23 13:15:59] |
With some data feeds you have to use different symbol prefixes for intraday and historical data afaik. For example IQFeed has it's own prefixes: http://www.sierrachart.com/index.php?l=doc/DTNIQFeed.html#Symbols http://www.iqfeed.net/symbolguide/index.cfm?symbolguide=guide&displayaction=support§ion=guide&web=iqfeed |
[2014-06-23 13:57:19] |
The responses before are from a user and not Sierra Chart Support. We need to know what Data or Trading service you are using Sierra Chart with? What is the File >> Data/Trade Service Settings >> Service set to? And we to know what the symbol is of the Intraday chart you are not getting data for? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-23 15:09:58] |
I use CTS for my data feed, and as far as I can remember, I've never had to use different symbol prefixes for intraday data. Could there be another underlying cause? Thank you.
[2014-06-23 15:13:33] |
The answers to your questions: CTS T4 FIX ES.20140900.CME_Eq |
[2014-06-23 18:34:08] |
I use CTS for my data feed, and as far as I can remember, I've never had to use different symbol prefixes for intraday data. Could there be another underlying cause? Thank you. This is not relevant to the issue.Post the Message Log, by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-24 12:39:54] |
Software version: 1141 | 2014-06-24 04:14:01 Usage end date: 2014-07-20 | 2014-06-24 04:14:01 Enabled for: Advanced Features. | 2014-06-24 04:14:01 Enabled for: Sierra Chart Historical Data Service. | 2014-06-24 04:14:01 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-06-24 04:14:01 Active service: CTS T4 FIX | 2014-06-24 04:14:01 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-06-24 04:14:01 2014-06-24 04:14:01 Local computer clock time | 2014-06-24 04:14:01 2014-06-24 09:14:01 GMT time | 2014-06-24 04:14:01 2014-06-24 04:14:01 Time zone adjusted time | 2014-06-24 04:14:01 Time difference to server time: 17 seconds. | 2014-06-24 04:14:01 Program path: C:\SierraChart2\ | 2014-06-24 04:14:01 Data Files path: C:\SierraChart2\Data\ | 2014-06-24 04:14:01 OS Version Number: 6.1 | 2014-06-24 04:14:01 Checking for new symbol settings for cts | 2014-06-24 04:14:01 Symbol settings are up-to-date for cts | 2014-06-24 04:14:02 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-06-24 04:14:06 CTS FIX - Firm: CTS | 2014-06-24 04:14:06 Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2014-06-24 04:14:06 The network socket is connected. | 2014-06-24 04:14:07 Starting SSL connection on the socket. | 2014-06-24 04:14:07 SSL socket is connected. | 2014-06-24 04:14:07 CTS FIX: Sending the Logon message. | 2014-06-24 04:14:07 CTS FIX: Connected to data and trade server. FIX version: 4.3.7.0 | 2014-06-24 04:14:08 CTS FIX: Received Account List collateral report. | 2014-06-24 04:14:08 CTS FIX: Subscribing to account: JN* | 2014-06-24 04:14:08 CTS FIX: Received Account Update collateral report. | 2014-06-24 04:14:10 CTS FIX: Requesting Open Orders for account: JN* | 2014-06-24 04:14:13 CTS FIX: Received Account List collateral report. | 2014-06-24 04:14:13 CTS FIX: Received Account List collateral report. | 2014-06-24 04:14:23 CTS T4 FIX - Starting real-time market data updates for: ES.20140900.CME_Eq. ID: 1 | 2014-06-24 04:14:41 HD Request # 2 - Downloading Historical Daily chart data for ESU14. Starting date: 2014-06-20. Service: cts | 2014-06-24 04:14:41 Historical data download counter reset. | 2014-06-24 04:14:41 HD Request # 2 - Requesting historical Daily data for ESU14 starting at 2014-06-19 | 2014-06-24 04:14:41 CTS T4 FIX: Sending security definition request for symbol ES.20140900.CME_Eq | 2014-06-24 04:14:41 HD Request # 2 - Receiving historical Daily data for ESU14 starting at 2014-06-19 | 2014-06-24 04:14:41 Writing historical Daily data for ESU14 to the file ESU14.dly | 2014-06-24 04:14:41 HD Request # 2 - Received 4 records from 2014-06-19 00:00:00 to 2014-06-24 00:00:00 (6.0 days) and wrote 3 records for ESU14 | 2014-06-24 04:14:41 HD Request # 2 - Daily download COMPLETE for ESU14. Completion time: 0s | 2014-06-24 04:14:41 CTS T4 FIX: Received matching security definition for symbol ES.20140900.CME_Eq. Subscribing to data. | 2014-06-24 04:14:41 CTS T4 FIX: Received 5 security definitions for underlying symbol ES | 2014-06-24 04:14:41 Symbol Error - ES.20140900.CME_Eq is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject message: (3) Exchange is not allowed for User | 2014-06-24 04:14:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\ES.20140900.CME_Eq.scid | 2014-06-24 04:14:54 HD Request # 3 - Downloading Intraday chart data for ES.20140900.CME_Eq to the file ES.20140900.CME_Eq.scid. Service: cts | 2014-06-24 04:14:55 HD Request # 3 - Download start Date-Time: 2013-12-20 03:14:55.0 | 2014-06-24 04:14:55 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-06-24 04:14:55 Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-06-24 04:14:55 The network socket is connected. | 2014-06-24 04:14:55 Starting SSL connection on the socket. | 2014-06-24 04:14:55 SSL socket is connected. | 2014-06-24 04:14:55 CTS FIX Historical Data: Sending the Logon message. | 2014-06-24 04:14:56 CTS FIX Historical Data: Connected to Historical data server. | 2014-06-24 04:14:56 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-20 00:00:00 to 2013-12-20 00:00:00 (US Central Time). | 2014-06-24 04:14:56 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:56 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-21 00:00:00 to 2013-12-21 00:00:00 (US Central Time). | 2014-06-24 04:14:56 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:56 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-22 00:00:00 to 2013-12-22 00:00:00 (US Central Time). | 2014-06-24 04:14:56 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:57 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-23 00:00:00 to 2013-12-23 00:00:00 (US Central Time). | 2014-06-24 04:14:57 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:57 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-24 00:00:00 to 2013-12-24 00:00:00 (US Central Time). | 2014-06-24 04:14:57 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:57 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-25 00:00:00 to 2013-12-25 00:00:00 (US Central Time). | 2014-06-24 04:14:57 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:57 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-26 00:00:00 to 2013-12-26 00:00:00 (US Central Time). | 2014-06-24 04:14:57 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:57 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-27 00:00:00 to 2013-12-27 00:00:00 (US Central Time). | 2014-06-24 04:14:57 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:58 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-28 00:00:00 to 2013-12-28 00:00:00 (US Central Time). | 2014-06-24 04:14:58 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:58 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-29 00:00:00 to 2013-12-29 00:00:00 (US Central Time). | 2014-06-24 04:14:58 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:58 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-30 00:00:00 to 2013-12-30 00:00:00 (US Central Time). | 2014-06-24 04:14:58 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:58 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2013-12-31 00:00:00 to 2013-12-31 00:00:00 (US Central Time). | 2014-06-24 04:14:58 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:58 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-01 00:00:00 to 2014-01-01 00:00:00 (US Central Time). | 2014-06-24 04:14:58 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:59 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-02 00:00:00 to 2014-01-02 00:00:00 (US Central Time). | 2014-06-24 04:14:59 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:59 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-03 00:00:00 to 2014-01-03 00:00:00 (US Central Time). | 2014-06-24 04:14:59 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:59 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-04 00:00:00 to 2014-01-04 00:00:00 (US Central Time). | 2014-06-24 04:14:59 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:59 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-05 00:00:00 to 2014-01-05 00:00:00 (US Central Time). | 2014-06-24 04:14:59 HD Request # 3 - Total records received: 0 | 2014-06-24 04:14:59 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-06 00:00:00 to 2014-01-06 00:00:00 (US Central Time). | 2014-06-24 04:14:59 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:00 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-07 00:00:00 to 2014-01-07 00:00:00 (US Central Time). | 2014-06-24 04:15:00 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:00 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-08 00:00:00 to 2014-01-08 00:00:00 (US Central Time). | 2014-06-24 04:15:00 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:00 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-09 00:00:00 to 2014-01-09 00:00:00 (US Central Time). | 2014-06-24 04:15:00 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:00 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-10 00:00:00 to 2014-01-10 00:00:00 (US Central Time). | 2014-06-24 04:15:00 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:00 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-11 00:00:00 to 2014-01-11 00:00:00 (US Central Time). | 2014-06-24 04:15:00 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:01 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-12 00:00:00 to 2014-01-12 00:00:00 (US Central Time). | 2014-06-24 04:15:01 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:01 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-13 00:00:00 to 2014-01-13 00:00:00 (US Central Time). | 2014-06-24 04:15:01 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:01 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-14 00:00:00 to 2014-01-14 00:00:00 (US Central Time). | 2014-06-24 04:15:01 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:01 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-15 00:00:00 to 2014-01-15 00:00:00 (US Central Time). | 2014-06-24 04:15:01 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:02 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-16 00:00:00 to 2014-01-16 00:00:00 (US Central Time). | 2014-06-24 04:15:02 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:02 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-17 00:00:00 to 2014-01-17 00:00:00 (US Central Time). | 2014-06-24 04:15:02 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:02 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-18 00:00:00 to 2014-01-18 00:00:00 (US Central Time). | 2014-06-24 04:15:02 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:02 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-19 00:00:00 to 2014-01-19 00:00:00 (US Central Time). | 2014-06-24 04:15:02 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:02 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-20 00:00:00 to 2014-01-20 00:00:00 (US Central Time). | 2014-06-24 04:15:02 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:03 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-21 00:00:00 to 2014-01-21 00:00:00 (US Central Time). | 2014-06-24 04:15:03 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:03 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-22 00:00:00 to 2014-01-22 00:00:00 (US Central Time). | 2014-06-24 04:15:03 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:03 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-23 00:00:00 to 2014-01-23 00:00:00 (US Central Time). | 2014-06-24 04:15:03 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:03 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-24 00:00:00 to 2014-01-24 00:00:00 (US Central Time). | 2014-06-24 04:15:03 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:03 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-25 00:00:00 to 2014-01-25 00:00:00 (US Central Time). | 2014-06-24 04:15:03 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:04 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-26 00:00:00 to 2014-01-26 00:00:00 (US Central Time). | 2014-06-24 04:15:04 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:04 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-27 00:00:00 to 2014-01-27 00:00:00 (US Central Time). | 2014-06-24 04:15:04 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:04 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-28 00:00:00 to 2014-01-28 00:00:00 (US Central Time). | 2014-06-24 04:15:04 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:05 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-29 00:00:00 to 2014-01-29 00:00:00 (US Central Time). | 2014-06-24 04:15:05 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:05 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-30 00:00:00 to 2014-01-30 00:00:00 (US Central Time). | 2014-06-24 04:15:05 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:05 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-01-31 00:00:00 to 2014-01-31 00:00:00 (US Central Time). | 2014-06-24 04:15:05 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:05 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-01 00:00:00 to 2014-02-01 00:00:00 (US Central Time). | 2014-06-24 04:15:05 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:05 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-02 00:00:00 to 2014-02-02 00:00:00 (US Central Time). | 2014-06-24 04:15:05 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:06 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-03 00:00:00 to 2014-02-03 00:00:00 (US Central Time). | 2014-06-24 04:15:06 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:06 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-04 00:00:00 to 2014-02-04 00:00:00 (US Central Time). | 2014-06-24 04:15:06 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:06 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-05 00:00:00 to 2014-02-05 00:00:00 (US Central Time). | 2014-06-24 04:15:06 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:06 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-06 00:00:00 to 2014-02-06 00:00:00 (US Central Time). | 2014-06-24 04:15:06 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:06 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-07 00:00:00 to 2014-02-07 00:00:00 (US Central Time). | 2014-06-24 04:15:06 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:07 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-08 00:00:00 to 2014-02-08 00:00:00 (US Central Time). | 2014-06-24 04:15:07 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:07 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-09 00:00:00 to 2014-02-09 00:00:00 (US Central Time). | 2014-06-24 04:15:07 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:07 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-10 00:00:00 to 2014-02-10 00:00:00 (US Central Time). | 2014-06-24 04:15:07 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:07 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-11 00:00:00 to 2014-02-11 00:00:00 (US Central Time). | 2014-06-24 04:15:07 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:08 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-12 00:00:00 to 2014-02-12 00:00:00 (US Central Time). | 2014-06-24 04:15:08 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:08 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-13 00:00:00 to 2014-02-13 00:00:00 (US Central Time). | 2014-06-24 04:15:08 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:08 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-14 00:00:00 to 2014-02-14 00:00:00 (US Central Time). | 2014-06-24 04:15:08 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:08 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-15 00:00:00 to 2014-02-15 00:00:00 (US Central Time). | 2014-06-24 04:15:08 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:08 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-16 00:00:00 to 2014-02-16 00:00:00 (US Central Time). | 2014-06-24 04:15:08 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:09 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-17 00:00:00 to 2014-02-17 00:00:00 (US Central Time). | 2014-06-24 04:15:09 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:09 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-18 00:00:00 to 2014-02-18 00:00:00 (US Central Time). | 2014-06-24 04:15:09 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:09 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-19 00:00:00 to 2014-02-19 00:00:00 (US Central Time). | 2014-06-24 04:15:09 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:09 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-20 00:00:00 to 2014-02-20 00:00:00 (US Central Time). | 2014-06-24 04:15:09 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:09 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-21 00:00:00 to 2014-02-21 00:00:00 (US Central Time). | 2014-06-24 04:15:09 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:10 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-22 00:00:00 to 2014-02-22 00:00:00 (US Central Time). | 2014-06-24 04:15:10 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:10 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-23 00:00:00 to 2014-02-23 00:00:00 (US Central Time). | 2014-06-24 04:15:10 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:10 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-24 00:00:00 to 2014-02-24 00:00:00 (US Central Time). | 2014-06-24 04:15:10 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:10 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-25 00:00:00 to 2014-02-25 00:00:00 (US Central Time). | 2014-06-24 04:15:10 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:10 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-26 00:00:00 to 2014-02-26 00:00:00 (US Central Time). | 2014-06-24 04:15:10 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:11 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-27 00:00:00 to 2014-02-27 00:00:00 (US Central Time). | 2014-06-24 04:15:11 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:11 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-02-28 00:00:00 to 2014-02-28 00:00:00 (US Central Time). | 2014-06-24 04:15:11 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:11 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-01 00:00:00 to 2014-03-01 00:00:00 (US Central Time). | 2014-06-24 04:15:11 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:11 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-02 00:00:00 to 2014-03-02 00:00:00 (US Central Time). | 2014-06-24 04:15:11 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:12 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-03 00:00:00 to 2014-03-03 00:00:00 (US Central Time). | 2014-06-24 04:15:12 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:12 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-04 00:00:00 to 2014-03-04 00:00:00 (US Central Time). | 2014-06-24 04:15:12 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:12 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-05 00:00:00 to 2014-03-05 00:00:00 (US Central Time). | 2014-06-24 04:15:12 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:12 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-06 00:00:00 to 2014-03-06 00:00:00 (US Central Time). | 2014-06-24 04:15:12 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:12 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-07 00:00:00 to 2014-03-07 00:00:00 (US Central Time). | 2014-06-24 04:15:12 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:13 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-08 00:00:00 to 2014-03-08 00:00:00 (US Central Time). | 2014-06-24 04:15:13 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:13 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-09 00:00:00 to 2014-03-09 00:00:00 (US Central Time). | 2014-06-24 04:15:13 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:13 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-10 00:00:00 to 2014-03-10 00:00:00 (US Central Time). | 2014-06-24 04:15:13 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:13 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-11 00:00:00 to 2014-03-11 00:00:00 (US Central Time). | 2014-06-24 04:15:13 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:13 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-12 00:00:00 to 2014-03-12 00:00:00 (US Central Time). | 2014-06-24 04:15:13 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:14 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-13 00:00:00 to 2014-03-13 00:00:00 (US Central Time). | 2014-06-24 04:15:14 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:14 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-14 00:00:00 to 2014-03-14 00:00:00 (US Central Time). | 2014-06-24 04:15:14 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:14 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-15 00:00:00 to 2014-03-15 00:00:00 (US Central Time). | 2014-06-24 04:15:14 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:14 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-16 00:00:00 to 2014-03-16 00:00:00 (US Central Time). | 2014-06-24 04:15:14 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:15 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-17 00:00:00 to 2014-03-17 00:00:00 (US Central Time). | 2014-06-24 04:15:15 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:15 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-18 00:00:00 to 2014-03-18 00:00:00 (US Central Time). | 2014-06-24 04:15:15 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:15 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-19 00:00:00 to 2014-03-19 00:00:00 (US Central Time). | 2014-06-24 04:15:15 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:15 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-20 00:00:00 to 2014-03-20 00:00:00 (US Central Time). | 2014-06-24 04:15:15 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:15 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-21 00:00:00 to 2014-03-21 00:00:00 (US Central Time). | 2014-06-24 04:15:15 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:16 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-22 00:00:00 to 2014-03-22 00:00:00 (US Central Time). | 2014-06-24 04:15:16 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:16 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-23 00:00:00 to 2014-03-23 00:00:00 (US Central Time). | 2014-06-24 04:15:16 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:16 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-24 00:00:00 to 2014-03-24 00:00:00 (US Central Time). | 2014-06-24 04:15:16 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:16 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-25 00:00:00 to 2014-03-25 00:00:00 (US Central Time). | 2014-06-24 04:15:16 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:16 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-26 00:00:00 to 2014-03-26 00:00:00 (US Central Time). | 2014-06-24 04:15:16 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:17 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-27 00:00:00 to 2014-03-27 00:00:00 (US Central Time). | 2014-06-24 04:15:17 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:17 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-28 00:00:00 to 2014-03-28 00:00:00 (US Central Time). | 2014-06-24 04:15:17 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:17 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-29 00:00:00 to 2014-03-29 00:00:00 (US Central Time). | 2014-06-24 04:15:17 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:17 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-30 00:00:00 to 2014-03-30 00:00:00 (US Central Time). | 2014-06-24 04:15:17 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:18 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-03-31 00:00:00 to 2014-03-31 00:00:00 (US Central Time). | 2014-06-24 04:15:18 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:18 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-01 00:00:00 to 2014-04-01 00:00:00 (US Central Time). | 2014-06-24 04:15:18 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:18 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-02 00:00:00 to 2014-04-02 00:00:00 (US Central Time). | 2014-06-24 04:15:18 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:18 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-03 00:00:00 to 2014-04-03 00:00:00 (US Central Time). | 2014-06-24 04:15:18 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:18 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-04 00:00:00 to 2014-04-04 00:00:00 (US Central Time). | 2014-06-24 04:15:18 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:19 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-05 00:00:00 to 2014-04-05 00:00:00 (US Central Time). | 2014-06-24 04:15:19 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:19 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-06 00:00:00 to 2014-04-06 00:00:00 (US Central Time). | 2014-06-24 04:15:19 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:19 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-07 00:00:00 to 2014-04-07 00:00:00 (US Central Time). | 2014-06-24 04:15:19 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:19 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-08 00:00:00 to 2014-04-08 00:00:00 (US Central Time). | 2014-06-24 04:15:19 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:19 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-09 00:00:00 to 2014-04-09 00:00:00 (US Central Time). | 2014-06-24 04:15:19 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:20 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-10 00:00:00 to 2014-04-10 00:00:00 (US Central Time). | 2014-06-24 04:15:20 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:20 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-11 00:00:00 to 2014-04-11 00:00:00 (US Central Time). | 2014-06-24 04:15:20 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:20 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-12 00:00:00 to 2014-04-12 00:00:00 (US Central Time). | 2014-06-24 04:15:20 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:20 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-13 00:00:00 to 2014-04-13 00:00:00 (US Central Time). | 2014-06-24 04:15:20 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:20 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-14 00:00:00 to 2014-04-14 00:00:00 (US Central Time). | 2014-06-24 04:15:20 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:21 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-15 00:00:00 to 2014-04-15 00:00:00 (US Central Time). | 2014-06-24 04:15:21 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:21 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-16 00:00:00 to 2014-04-16 00:00:00 (US Central Time). | 2014-06-24 04:15:21 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:21 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-17 00:00:00 to 2014-04-17 00:00:00 (US Central Time). | 2014-06-24 04:15:21 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:21 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-18 00:00:00 to 2014-04-18 00:00:00 (US Central Time). | 2014-06-24 04:15:21 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:22 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-19 00:00:00 to 2014-04-19 00:00:00 (US Central Time). | 2014-06-24 04:15:22 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:22 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-20 00:00:00 to 2014-04-20 00:00:00 (US Central Time). | 2014-06-24 04:15:22 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:22 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-21 00:00:00 to 2014-04-21 00:00:00 (US Central Time). | 2014-06-24 04:15:22 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:22 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-22 00:00:00 to 2014-04-22 00:00:00 (US Central Time). | 2014-06-24 04:15:22 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:22 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-23 00:00:00 to 2014-04-23 00:00:00 (US Central Time). | 2014-06-24 04:15:22 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:23 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-24 00:00:00 to 2014-04-24 00:00:00 (US Central Time). | 2014-06-24 04:15:23 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:23 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-25 00:00:00 to 2014-04-25 00:00:00 (US Central Time). | 2014-06-24 04:15:23 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:23 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-26 00:00:00 to 2014-04-26 00:00:00 (US Central Time). | 2014-06-24 04:15:23 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:23 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-27 00:00:00 to 2014-04-27 00:00:00 (US Central Time). | 2014-06-24 04:15:23 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:23 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-28 00:00:00 to 2014-04-28 00:00:00 (US Central Time). | 2014-06-24 04:15:23 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:24 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-29 00:00:00 to 2014-04-29 00:00:00 (US Central Time). | 2014-06-24 04:15:24 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:24 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-04-30 00:00:00 to 2014-04-30 00:00:00 (US Central Time). | 2014-06-24 04:15:24 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:24 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-01 00:00:00 to 2014-05-01 00:00:00 (US Central Time). | 2014-06-24 04:15:24 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:24 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-02 00:00:00 to 2014-05-02 00:00:00 (US Central Time). | 2014-06-24 04:15:24 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:24 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-03 00:00:00 to 2014-05-03 00:00:00 (US Central Time). | 2014-06-24 04:15:24 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:25 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-04 00:00:00 to 2014-05-04 00:00:00 (US Central Time). | 2014-06-24 04:15:25 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:25 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-05 00:00:00 to 2014-05-05 00:00:00 (US Central Time). | 2014-06-24 04:15:25 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:25 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-06 00:00:00 to 2014-05-06 00:00:00 (US Central Time). | 2014-06-24 04:15:25 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:25 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-07 00:00:00 to 2014-05-07 00:00:00 (US Central Time). | 2014-06-24 04:15:25 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:26 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-08 00:00:00 to 2014-05-08 00:00:00 (US Central Time). | 2014-06-24 04:15:26 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:26 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-09 00:00:00 to 2014-05-09 00:00:00 (US Central Time). | 2014-06-24 04:15:26 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:26 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-10 00:00:00 to 2014-05-10 00:00:00 (US Central Time). | 2014-06-24 04:15:26 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:26 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-11 00:00:00 to 2014-05-11 00:00:00 (US Central Time). | 2014-06-24 04:15:26 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:26 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-12 00:00:00 to 2014-05-12 00:00:00 (US Central Time). | 2014-06-24 04:15:26 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:27 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-13 00:00:00 to 2014-05-13 00:00:00 (US Central Time). | 2014-06-24 04:15:27 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:27 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-14 00:00:00 to 2014-05-14 00:00:00 (US Central Time). | 2014-06-24 04:15:27 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:27 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-15 00:00:00 to 2014-05-15 00:00:00 (US Central Time). | 2014-06-24 04:15:27 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:27 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-16 00:00:00 to 2014-05-16 00:00:00 (US Central Time). | 2014-06-24 04:15:27 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:27 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-17 00:00:00 to 2014-05-17 00:00:00 (US Central Time). | 2014-06-24 04:15:27 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:28 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-18 00:00:00 to 2014-05-18 00:00:00 (US Central Time). | 2014-06-24 04:15:28 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:28 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-19 00:00:00 to 2014-05-19 00:00:00 (US Central Time). | 2014-06-24 04:15:28 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:28 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-20 00:00:00 to 2014-05-20 00:00:00 (US Central Time). | 2014-06-24 04:15:28 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:28 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-21 00:00:00 to 2014-05-21 00:00:00 (US Central Time). | 2014-06-24 04:15:28 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:28 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-22 00:00:00 to 2014-05-22 00:00:00 (US Central Time). | 2014-06-24 04:15:28 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:29 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-23 00:00:00 to 2014-05-23 00:00:00 (US Central Time). | 2014-06-24 04:15:29 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:29 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-24 00:00:00 to 2014-05-24 00:00:00 (US Central Time). | 2014-06-24 04:15:29 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:29 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-25 00:00:00 to 2014-05-25 00:00:00 (US Central Time). | 2014-06-24 04:15:29 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:29 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-26 00:00:00 to 2014-05-26 00:00:00 (US Central Time). | 2014-06-24 04:15:29 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:30 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-27 00:00:00 to 2014-05-27 00:00:00 (US Central Time). | 2014-06-24 04:15:30 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:30 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-28 00:00:00 to 2014-05-28 00:00:00 (US Central Time). | 2014-06-24 04:15:30 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:30 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-29 00:00:00 to 2014-05-29 00:00:00 (US Central Time). | 2014-06-24 04:15:30 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:30 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-30 00:00:00 to 2014-05-30 00:00:00 (US Central Time). | 2014-06-24 04:15:30 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:30 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-05-31 00:00:00 to 2014-05-31 00:00:00 (US Central Time). | 2014-06-24 04:15:30 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:31 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-01 00:00:00 to 2014-06-01 00:00:00 (US Central Time). | 2014-06-24 04:15:31 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:31 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-02 00:00:00 to 2014-06-02 00:00:00 (US Central Time). | 2014-06-24 04:15:31 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:31 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-03 00:00:00 to 2014-06-03 00:00:00 (US Central Time). | 2014-06-24 04:15:31 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:31 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-04 00:00:00 to 2014-06-04 00:00:00 (US Central Time). | 2014-06-24 04:15:31 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:31 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-05 00:00:00 to 2014-06-05 00:00:00 (US Central Time). | 2014-06-24 04:15:31 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:32 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-06 00:00:00 to 2014-06-06 00:00:00 (US Central Time). | 2014-06-24 04:15:32 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:32 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-07 00:00:00 to 2014-06-07 00:00:00 (US Central Time). | 2014-06-24 04:15:32 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:32 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-08 00:00:00 to 2014-06-08 00:00:00 (US Central Time). | 2014-06-24 04:15:32 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:32 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-09 00:00:00 to 2014-06-09 00:00:00 (US Central Time). | 2014-06-24 04:15:32 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:32 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-10 00:00:00 to 2014-06-10 00:00:00 (US Central Time). | 2014-06-24 04:15:32 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:33 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-11 00:00:00 to 2014-06-11 00:00:00 (US Central Time). | 2014-06-24 04:15:33 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:33 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-12 00:00:00 to 2014-06-12 00:00:00 (US Central Time). | 2014-06-24 04:15:33 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:33 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-13 00:00:00 to 2014-06-13 00:00:00 (US Central Time). | 2014-06-24 04:15:33 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:33 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-14 00:00:00 to 2014-06-14 00:00:00 (US Central Time). | 2014-06-24 04:15:33 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:34 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-15 00:00:00 to 2014-06-15 00:00:00 (US Central Time). | 2014-06-24 04:15:34 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:34 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-16 00:00:00 to 2014-06-16 00:00:00 (US Central Time). | 2014-06-24 04:15:34 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:34 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-17 00:00:00 to 2014-06-17 00:00:00 (US Central Time). | 2014-06-24 04:15:34 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:34 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-18 00:00:00 to 2014-06-18 00:00:00 (US Central Time). | 2014-06-24 04:15:34 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:34 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-19 00:00:00 to 2014-06-19 00:00:00 (US Central Time). | 2014-06-24 04:15:34 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:35 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-20 00:00:00 to 2014-06-20 00:00:00 (US Central Time). | 2014-06-24 04:15:35 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:35 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-21 00:00:00 to 2014-06-21 00:00:00 (US Central Time). | 2014-06-24 04:15:35 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:35 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-22 00:00:00 to 2014-06-22 00:00:00 (US Central Time). | 2014-06-24 04:15:35 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:35 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-23 00:00:00 to 2014-06-23 00:00:00 (US Central Time). | 2014-06-24 04:15:35 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:35 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-24 00:00:00 to 2014-06-24 00:00:00 (US Central Time). | 2014-06-24 04:15:35 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:36 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-25 00:00:00 to 2014-06-25 00:00:00 (US Central Time). | 2014-06-24 04:15:36 HD Request # 3 - Total records received: 0 | 2014-06-24 04:15:36 HD Request # 3 - Requesting historical Second data for ES.20140900.CME_Eq from 2014-06-26 00:00:00 to 2014-06-26 00:00:00 (US Central Time). | 2014-06-24 04:15:36 HD Request # 3 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20140900.CME_Eq | 2014-06-24 04:15:36 HD Request # 3 - Intraday download COMPLETE for ES.20140900.CME_Eq. Completion time: 41s | 2014-06-24 04:15:36 Real-time Intraday chart data file updates started for ES.20140900.CME_Eq | 2014-06-24 04:15:36 CTS FIX Historical Data: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2014-06-24 04:17:36 CTS FIX Historical Data: Sending a Logout message. Text = Received Logout message. | 2014-06-24 04:17:36 SSL shutdown indicates not able to send 'close notify'. | 2014-06-24 04:17:36 The SSL socket has been shut down. | 2014-06-24 04:17:36 The SSL socket object has been freed. SSL state is now disconnected. | 2014-06-24 04:17:36 Socket has been shutdown and closed. | 2014-06-24 04:17:36 CTS FIX Historical Data: Logged out and disconnected. | 2014-06-24 04:17:36 CTS FIX Historical Data: Disconnected. | 2014-06-24 04:17:36 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\ES.20140900.CME_Eq.scid | 2014-06-24 04:18:23 |
[2014-06-24 16:48:14] |
This is the reason for the problem: Symbol Error - ES.20140900.CME_Eq is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject message: (3) Exchange is not allowed for User | 2014-06-24 04:14:41
Contact your broker/trading service and let them know you need to be allowed the exchange for the ES futures. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
