Date/Time: Thu, 02 May 2024 09:29:12 +0000
Highest High/Lowest Low over N Bars - line drawn at multiple val
View Count: 2011
[2013-05-02 12:35:44] |
T44 - Posts: 363 |
On the above study, I would expect it to plot a single horizontal line. Instead, it appears to calculate what the prior N bar high / low would have been for each bar on the chart. I asked about this on another thread, Drawing line at all time high - performance issue and was told: "This problem will be resolved in the next release." I have installed the new release today, and the lines still plot multiple values. (ie a different value for each bar displayed on the chart, not a single value for the highest high (lowest low) of the prior N bars from current bar. Will this be fixed, or have I misunderstood how the study is meant to work? How can I achieve the desired effect of 1 line? |
[2013-05-02 22:44:01] |
Please post an image of the chart that uses this study, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-03 09:04:33] |
T44 - Posts: 363 |
I'd have expected a single line at 4.44 and 3.986. I do not know why it is calculating on prior bars and would like a way to turn this off. Thanks. |
SC_nBarHighLow_example.png / V - Attached On 2013-05-03 09:04:29 UTC - Size: 33.07 KB - 568 views |
[2013-05-03 13:16:25] |
This study does not do what you want. You would have to custom program what you need. Please see: http://www.sierrachart.com/index.php?l=doc/doc_WorksheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-03 13:16:37
