Date/Time: Mon, 20 May 2024 01:16:08 +0000
rsi
View Count: 888
[2014-06-22 17:14:52] |
User49421 - Posts: 21 |
Hi there, Im used to using an rsi with a 14 day period line with a marker at 30 and 70. However the rsi on your charts also includes an rsi average. How do i remove this line. Thanks Ahmed |
[2014-06-22 20:26:35] |
You need to set the Draw Style for the study Subgraphs you do not want to see to Ignore. This is done through the Study Settings >> Subgraphs tab. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#DrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
