Date/Time: Sun, 05 May 2024 10:35:20 +0000
Custom Study Compile Problem v1149
View Count: 1072
[2014-06-22 05:37:07] |
ChrisH - Posts: 10 |
Hello, I have a problem when attempting to build a custom study. No DLL file is created & no error is displayed. The build takes but a second. I found similar issues on the support board but deleting CPPCompiler folder & re-installing compiler did not work. I'm using a WinXP machine. I was on build 1115, upgraded to 1149 & then downgraded to 1091 (version that works on a different pc). Build results: -- Starting build of Custom Studies Source files: STATISTICS.cpp. -- 22:28:59 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\STATISTICS.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\STATISTICS.dll" -- End of Build -- 22:29:00 Thanks, Chris |
[2014-06-22 15:50:55] |
This is a problem with the latest CPP compiler which we do not develop. We are looking into the issue.
[2014-06-22 17:13:10] |
User37462 - Posts: 31 |
I have the same issue as Chris
[2014-06-22 19:54:25] |
We can duplicate the problem . We are going to do our best to get the developers of the MinGW compiler to solve this as soon as possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-23 03:44:59] |
Update: I overwrote the v1091 SierraChart files on my desktop (except for \data & \ACS_Source folders) from my problem free v1091 copy on my laptop. I'm now able to compile studies on my desktop again.
[2014-06-23 04:22:58] |
OK. However, there still is a problem with the newest compiler. We are contacting the developers about it. Also, you could update Sierra Chart itself to the latest version. The problem is with the MinGW compiler that is installed into the CPPCompiler subfolder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-23 04:24:10
[2014-06-24 06:09:37] |
We now know why this problem is happening. Refer to: Resolved: No DLL File Generated with Built-In Sierra Chart Compiler Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
