Date/Time: Sat, 04 May 2024 19:10:35 +0000
Trade activity log:problem
View Count: 956
[2014-06-21 19:52:33] |
User99689 - Posts: 27 |
Hello support team, Since the 28/04/2014 runup, drawdown, max open profit max open loss are "0", before this date i had these data. Can you tell me why ? How long trade activity log is store ? Thanks |
[2014-06-21 20:09:07] |
Do you have Trade >>Use Fill Calculated Positions-Global checked? The number of days stored in the Trade Activity Log is set to Trade >> General Trade Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-21 21:26:49] |
yes it is checked, should i uncheck it to find lost datas? ok for days stored thanks support Date Time Of Last Edit: 2014-06-21 21:28:51
[2014-06-22 02:05:11] |
When Trade >> Use Fill Calculated Positions-Global is checked, there will not be high and low price data maintained for current Trade Positions which causes the runup and drawdown and related statistics to always be 0.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-22 02:05:40
