Date/Time: Fri, 03 May 2024 13:32:59 +0000
[User Discussion] - Lines around senko span
View Count: 945
[2014-06-21 18:10:06] |
User49421 - Posts: 21 |
Hi, I have separate colours for the kumo cloud, but i would like to have an individual lines which outlines the kumo cloud, for senko a + b, so when they interchange i can see. How would i be able to do this. Regards Ahmed |
[2014-06-25 21:00:03] |
vegasfoster - Posts: 444 |
You can put two of the studies on your chart and then change the plot for the second study to lines and change their color.
[2014-06-26 06:57:38] |
The answer given in post #2 is the general method to do this. Let us know if you need specific instructions.
