Date/Time: Sat, 04 May 2024 12:54:21 +0000
Historical Intraday data not downloading
View Count: 2108
[2013-05-02 11:57:23] |
RMF2 - Posts: 43 |
Hi, Historical intraday data is not downloading. I tried to update ZSN3 from 5/1/13 13:52 to this morning and no records were received. Here's the message log from the update: Connecting to Open E Cry server: prod.openecry.com:9200... | 2013-05-02 06:50:53 Connected to OEC. | 2013-05-02 06:50:54 Starting updates for: ZSN3 | 2013-05-02 06:50:54 HD Request # 39 - Downloading Intraday chart data for ZSN3 to the file ZSN3.scid. Service: scsrv | 2013-05-02 06:50:54 HD Request # 39 - Starting date and time: 2013-05-02 06:13:31 | 2013-05-02 06:50:54 HD Request # 39 - Using server: ds5.sierracharts.com port 10049 | 2013-05-02 06:50:54 Open E Cry tick subscription ID: 28 | 2013-05-02 06:50:55 HD Request # 39 - Requesting up to 3650 days of Intraday data. | 2013-05-02 06:50:55 HD Request # 39 - Decompressing data. | 2013-05-02 06:50:55 HD Request # 39 - Received 0 records and wrote 0 records for ZSN3 | 2013-05-02 06:50:55 HD Request # 39 - Intraday download COMPLETE for ZSN3 | 2013-05-02 06:50:55 Real-time intraday chart data file updates started for ZSN3 | 2013-05-02 06:50:55 Please advise. Thank you. |
[2013-05-02 20:13:46] |
We are checking on this.
[2013-05-02 21:59:49] |
We have contacted OEC about this. The source of the issue just has to do with a limitation on the OEC side. We hope to have it resolved as soon as possible.
[2013-05-07 00:46:04] |
The data for this symbol is now available. You can re-download it by selecting Edit >> Delete All Data and Download
[2013-05-07 15:42:13] |
RMF2 - Posts: 43 |
Data is downloading but it does not match ZSN3 data. Also, the data is missing bid and ask volume prior to the evening session.
[2013-05-07 16:08:30] |
The data will be missing Bid volume and Ask volume for the areas that we had to fill it in. This is true. What exactly do you mean by " does not match ZSN3 data"? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-07 17:15:14] |
RMF2 - Posts: 43 |
Here's what the chart looks like. The data in the chart was refreshed towards the end of the RTH session, April 30th. http://www.sierrachart.com/image.php?l=1367946769693.png |
[2013-05-07 20:08:51] |
We did see some missing data on some of the servers. This has been restored. To ensure you have all of the data re-download by selecting Edit >> Delete All Data and Download. The data you show in that chart though is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-08 00:22:39] |
RMF2 - Posts: 43 |
I have attached an Excel file comparing data recorded from a real-time session with data downloaded this evening covering the date 5/1/2013 from 21:30 to 21:53. The prices and time prints do not match. |
Data Comparison.xlsx - Attached On 2013-05-08 00:20:06 UTC - Size: 17.3 KB - 582 views |
[2013-05-08 01:57:10] |
The data you see in the chart comes from OEC. Unless we believe there is a problem, it is outside the scope of our support to be taking the time to look at this Excel file. We do not believe there is a problem here. You also need to make certain that when you are comparing the times, you are looking at the same time zone. Here is a chart image for the same symbol using IQ Feed: http://www.sierrachart.com/image.php?l=1367977896305.png The time zone is New York. It looks the same to us. In any case, the data is not ours, it comes from an exchange. We have refreshed the data from OEC, and you have re-downloaded it. We cannot provide further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-08 01:58:08
