Date/Time: Thu, 02 May 2024 03:03:00 +0000
[User Discussion] - Cancel order if price misses by x points/ticks
View Count: 994
[2014-06-20 07:29:25] |
User11644 - Posts: 16 |
Hi, Is there a way to have SC automatically cancel a limit order if price misses by x points/ticks. i.e. price moves within 5 ticks of potential order area then moves 10 ticks away which could invalidate my systems entry criteria. thanks |
[2014-06-20 08:29:40] |
You would have to custom program this. We recommend using the ACSIL trading functions: http://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-20 08:39:27] |
Is this not a feature you could implement in your product? I'm not looking to learn how to code. Thanks.
[2014-06-20 08:49:13] |
No.
