Date/Time: Mon, 13 May 2024 14:08:46 +0000
Teton Futures Order Routing
View Count: 338
[2023-04-10 16:58:08] |
User585993 - Posts: 79 |
Can I use the Teton Futures Order Routing with Rithmic ( data provided by an evaluation company) Thanks! |
[2023-04-10 18:43:53] |
John - SC Support - Posts: 31555 |
You can not do this. Rithmic is an order routing service. The evaluation company you are working with only works with Rithmic for their order routing purposes. Separately, if you are asking if you can use the Rithmic data with the Teton Order Routing Service for your personal account, the answer is still No. You can not bring in data from an external source and use that with a different trading service. The opposite, however, is that you CAN use our Denali data with any other trading service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
