Date/Time: Sun, 28 Apr 2024 21:43:02 +0000
HE charts
View Count: 1000
[2014-06-20 02:04:18] |
arrow - Posts: 52 |
I cannot see rollover dates on the Lean Hogs daily charts. Also the Daily and weekly prices are so far off I cannot use them together. The highs from March are about 16.5 off with the weekly being higher. I'm using CTS, is the price difference on their end or something you guys can fix?
Date Time Of Last Edit: 2014-06-20 02:12:36
[2014-06-20 19:00:13] |
We need to understand this better. Post an image of the chart by following these instructions here: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Please only use this method to post an image of the chart and no other method. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-21 01:36:58] |
arrow - Posts: 52 |
Here is the HE daily and weekly showing the price difference and an LE daily showing the rollover dates. HE is the only one I'm having problems with regarding the price difference and not being able to display rollover dates.
Attachment Deleted. HEDaily.png / V - Attached On 2014-06-21 01:35:43 UTC - Size: 44.24 KB - 336 views HEWeekly.png / V - Attached On 2014-06-21 01:35:48 UTC - Size: 53.44 KB - 311 views LEDaily.png / V - Attached On 2014-06-21 01:35:53 UTC - Size: 53.47 KB - 321 views |
[2014-06-21 08:10:49] |
arrow - Posts: 52 |
I'm sorry never mind this I just realized my mistake. It's all good everything is working as it should.
[2014-06-21 16:50:19] |
This is good. What we see is the Daily chart is not set to a Continuous Futures Contract chart. And the HE charts do not have Chart >> Show Rollover Dates enabled.
