Date/Time: Thu, 02 May 2024 10:02:45 +0000
chart windows do not open
View Count: 901
[2014-06-19 16:44:31] |
fsovir - Posts: 14 |
hello, SierraChart was frozen this morning: chart windows were frozen at circa 50% of the loading operation. A window appeared telling me SierraChart has stopped. I installed the last version. SierraChart opens but no chart Windows are displayed. How can I retrieve my chart windows, please. Thank you for your help, regards, So |
[2014-06-19 17:11:08] |
This may be due to custom studies which need to be recompiled for the current version of Sierra Chart. Refer to help topic 17 here: http://www.sierrachart.com/index.php?l=doc/helpdetails17.html If you are still having trouble opening your Chartbook, then refer to help topic 30.16 here: https://www.sierrachart.com/index.php?l=doc/helpdetails30.html#h30.16 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
