Date/Time: Sat, 04 May 2024 02:14:43 +0000
Indicators
View Count: 918
[2014-06-19 14:35:11] |
gmorgan111 - Posts: 121 |
Is it possible to take an indicator currently running on one chart with one instrument and time frame and transfer this same indicator to another chart and instrument and time frame and ye have it running with the data from the first chart? thanks |
[2014-06-19 18:18:02] |
Yes. This is supported. Refer to help topic 28 here: http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
