Date/Time: Sat, 04 May 2024 12:15:03 +0000
TICK - waiting to download data
View Count: 873
[2014-06-19 14:00:34] |
User30743 - Posts: 364 |
hi there, there is something wrong today with my tick indicator. it keeps telling me it is waiting to download histroical data.. and nothing is happening.. what is the problem please? viz http://www.sierrachart.com/image.php?l=1403186293556.png |
[2014-06-19 17:18:22] |
Select File >> Disconnect and File >> Connect to Data Feed. If you continue to notice this problem, then refer to this help topic: https://www.sierrachart.com/index.php?l=doc/helpdetails41.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-19 17:19:02
