Date/Time: Fri, 03 May 2024 17:48:06 +0000
Alerts
View Count: 920
[2014-06-19 12:41:16] |
User96441 - Posts: 16 |
Even when I select an alert to go off once per bar it goes off every time it crossed the trigger, which can be many times if price is chopping for a bit and with multiple alerts it becomes a hindrance rather than a help. How do I get them to alert once per bar? Many Thanks
[2014-06-19 18:34:31] |
Are you referring to a Simple Alert for a study? And is this Alert Formula on more than one chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-19 18:44:09
[2014-06-20 07:14:38] |
That is a yes to both questions? Thanks
[2014-06-22 01:51:27] |
Just make sure you have Alert Only Once per Bar enabled: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#AlertOptions Go to Window >> Show/Hide Alerts Manager >> Alerts Log. Do you see 2 alerts for the same study instance for the same bar, when you have Alert Only Once per Bar enabled? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-22 01:52:07
