Date/Time: Tue, 07 May 2024 12:38:45 +0000
Compiling problem with V 1148 ?
View Count: 955
[2014-06-19 12:31:35] |
wwwingman - Posts: 185 |
Hi, I just upgraded from 1137 to 1148 and have a compiling problem with sierrachart.h For ex, with the sierra template -- Starting build of Custom Studies Source files: Template.cpp. -- 08:26:17 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\Template.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\Template.dll" In file included from C:\SierraChart\ACS_Source\Template.cpp:2:0: C:\SierraChart\ACS_Source\sierrachart.h:5334:22: error: expected identifier before '*' token C:\SierraChart\ACS_Source\sierrachart.h:5334:24: warning: '__cdecl__' attribute only applies to function types [-Wattributes] C:\SierraChart\ACS_Source\sierrachart.h:5334:74: error: ISO C++ forbids declaration of 'SCString' with no type [-fpermissive] C:\SierraChart\ACS_Source\sierrachart.h:5334:74: error: 'SCString' declared as function returning a function -- End of Build -- 08:26:18 Am I doing something wrong ? this worked perfectly during the past versions. W. |
[2014-06-19 16:40:08] |
This will be solved in the next release which we are going to be releasing in about 30 minutes.
[2014-06-19 17:57:35] |
We have released a new revision which solves this problem. The version number is the same. To update select Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
