Date/Time: Sun, 05 May 2024 01:54:38 +0000
Study - "Volume by price" time zone
View Count: 1086
[2014-06-19 07:47:40] |
User17064 - Posts: 70 |
Hi SC support, Currently I use the Volume by price study, for the "period type", I select Multiple Profiles from start time to end time.And then I input the start and end time. May I ask is there anyway I could set the timezone userd for this study? Since in this chart I use Asia Time zone, but for this indicator I would like to use US session. Thank you |
[2014-06-19 09:50:29] |
You can independently set the time zone in a chart through Chart >> Chart Settings >> Advanced Settings >> Time Zone.
[2014-06-20 01:11:28] |
Yes.I mean in that chart time zone, I set it to my local time zone cause it is easier for me to identify the proper time. But for the study indicator, I would like it to use US session time zone,is there any way to do that?
[2014-06-20 01:15:03] |
No. The chart and the studies will use the same time zone.
