Date/Time: Sun, 05 May 2024 03:25:23 +0000
Simple custom chart study - how to create
View Count: 1129
[2014-06-18 19:38:36] |
User11942 - Posts: 298 |
Hello SC, I’d like to know how I may create a custom chart study with visual (e.g. arrow)/sound alerts. It should be a very simple study where if price is crossed (upward or downward), for example a moving average/BB line/anything else (by my choice), an alert is triggered immediately or on the start of the next bar (again by the choice). Maybe some ready templates or clear examples available? What’s the easiest way to do that? I tried to search the board, but didn't find an exact answer. Thanks. Date Time Of Last Edit: 2014-06-18 21:21:29
[2014-06-28 18:35:19] |
You will want to use the Color Bar Based on Alert Condition study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 It can also draw arrows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
