Date/Time: Tue, 07 May 2024 19:24:05 +0000
Rithmic tick-nyse
View Count: 1645
[2014-06-18 17:47:02] |
stephensmart - Posts: 51 |
Hi, i am using rithmic feed, and i cant locate tick-nyse, under find symbol, instance, "rithmic trading" is the only available option, greyed out, and only the futures contracts are displayed no market stats.
[2014-06-18 18:13:34] |
Update with Help >> Download Current Version.
[2014-06-18 18:20:20] |
perfect thanks, and to place the tick-nyse below my price chart but on the same chart?
[2014-06-18 22:23:09] |
This is explained here: http://www.sierrachart.com/index.php?l=doc/SCMarketStatistics.php#Overlaying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
