Date/Time: Mon, 06 May 2024 13:56:01 +0000
[User Discussion] - Overlay of MACD ZERO CROSS OVER SYSTEM from higher to lower time frame
View Count: 1070
[2014-06-18 01:14:53] |
teowinner - Posts: 16 |
Hi guys, I use a 5 mins chart with the MACD ZERO CROSS OVER SYSTEM from the Standard Studies list with the standard default settings, when MACD cross zero, it will show either a up arrow or down arrow depends it is above or below, it works fine on the 5 mins chart. I also set this studies with a minus 1 displacement on the subgraph panel. I then overlay this study onto a 1 min time frame, it did shows the past arrows, when time goes by, when a new arrow comes out from the 5 min chart, it does not reflect on the 1 min, what I do is click on the RECALCULATE function, then the arrow pop up. I tries on various time frames, it is the same problem. Sincerely hope that this is can be put in order by your expertise. Thanks you always! |
