Date/Time: Tue, 07 May 2024 07:14:48 +0000
Market Profile - remains at D period, omitting C period
View Count: 1102
[2014-06-17 15:22:34] |
CHTrader - Posts: 7 |
Market Profile does not change the 30 minute letters after the second 30 minute period. See attached file. A period is from 9:30 to 10:00 ET.
MPerror.png / V - Attached On 2014-06-17 15:21:23 UTC - Size: 34.71 KB - 332 views |
[2014-06-17 16:27:50] |
What do you have the TPO Letter Sequence input with the TPO Profile Chart study set to?
[2014-06-17 16:32:18] |
The sequence is: ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz What is also strange: this error only occurred in today's graph. Yesterday's is correct. |
TPOSequence.png / V - Attached On 2014-06-17 16:31:46 UTC - Size: 113.61 KB - 343 views |
[2014-06-17 17:42:44] |
If prior TPO Profiles are not showing this problem, this would indicate a problem with the underlying data. Right-click before the TPO profiles that do not look correct and select Delete and Download Data. If that does not work, then open a new chart for the symbol and look at the bars and see if there any repeating or out of order times at the bottom. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
