Date/Time: Fri, 03 May 2024 14:51:03 +0000
Trailing stop tick value
View Count: 346
[2023-03-16 16:57:46] |
User257117 - Posts: 10 |
How to add a trailing stop to an active trade that will move by a certain amount of ticks relative to the current price? (E.g. 30 or 35 ticks from the current price)
[2023-03-16 17:18:42] |
John - SC Support - Posts: 31339 |
To add an Attached Order to an existing position, you need to use the Send Attached Orders order type. Refer to the following: Order Types: Send Attached Orders - Position/Price In terms of the Trailing Stop, refer to the configuration example in the section linked here: Attached Orders: Trade Window Configuration File Examples For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-09 08:10:30] |
I have tested the attached orders with tralling stop and when inserting an order with defined "stop offset" tralling stop works as I want. My question, however, is whether I can insert a trailing stop into an active trade (remove the regular stop loss and insert a trailing stop specifying the interval from the current price, e.g. exactly 30t from the current price). From the trade window on the chart, it is possible to set a trailing stop at the selected price (use attached orders when unchecked), but it is not possible to hit the exact distance from the current price this way. Is there another possibility? |
[2023-05-09 09:01:41] |
Sierra_Chart Engineering - Posts: 14198 |
Try using the method documented here: Order Types: Send Attached Orders - Position/Price Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-09 10:18:49] |
Send Attached Orders by Price after editing the stop offset in trade window for chart works great. Topic finished.
