Date/Time: Sun, 28 Apr 2024 11:39:54 +0000
Sub instance 3 doesn´t load charts
View Count: 260
[2023-03-13 05:38:15] |
User565974 - Posts: 32 |
Hi, since today morning, after starting SC, only sub instance 3 (total 4) isnĀ“t loading charts, and additionally all my screens gone black, recovered and sub instance 3 dissapeared. Looked at my graphic cards - they are ok. Now I have running main, sub instance 2 and 4 but 3 is gone - how is that possible?? |
SC Sub 3 frozen.png / V - Attached On 2023-03-13 05:36:23 UTC - Size: 59.48 KB - 55 views |
[2023-03-13 09:01:27] |
Sierra_Chart Engineering - Posts: 14111 |
Are the symbols of the charts correct? Refer to: Data/Trading Service Connection and Symbol Issues: 1.3. Symbols Go to one of the charts and select Chart >> Reload and Recalculate. Also refer to: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-13 09:20:39
[2023-03-13 09:56:32] |
Hi, thanks, I found the misstake in the morning - it was the openGL (my fault)! I thought I replied already - anyway! thanks for quick response! Have a nice week! |
