Date/Time: Mon, 29 Apr 2024 18:41:32 +0000
Time Sessions / Global Time
View Count: 869
[2023-03-13 07:31:01] |
User585104 - Posts: 114 |
Tony what you have said is wrong again and wasting his time. Correct setting using your own method would be: Intraday Session from: 13:30:00 to 21:00:00 Evening Session: from 22:00:00 to 13:29:59 Not as you have stated Intraday Session from: 13:30:00 to 21:59:59 Evening Session: from 22:00:00 to 13:29:59 Tin43 trust me and just do what I have said in my original responses. Forget all this other stuff |
[2023-03-13 08:02:36] |
Tin43 - Posts: 75 |
Ok, thanks User58. I don't want to mess this any more than it is. but Does this will affect if I trade the Dax and FTSE? Do i have to change the sessions for that instruments or something? |
[2023-03-13 08:12:52] |
Np, your question was an easy question with an easy answer =] If a different chart is for the FTSE 100 set that chart to London time and set the open/close hours on it. I dont know the open/close local times for anything else but you can easily look them up. I only know about the CME ES but it is the same set up method of charts for everything. Any new chart set it to the local time for the instrument and set the sessions times correctly on that new chart Date Time Of Last Edit: 2023-03-13 08:16:32
[2023-03-13 12:20:29] |
Tin43 - Posts: 75 |
Man. thanks a LOT! Is there a way to add you as a "friend" here or something. I promise I will not DM ever day and things like that. Just for having a reference. |
[2023-03-13 12:22:23] |
I accepted your request, you'll have to accept mine =]
[2023-03-13 13:49:20] |
Tin43 - Posts: 75 |
Done!!! |
