Date/Time: Fri, 26 Apr 2024 03:22:11 +0000
Order cancel reject; the order is not in the book
View Count: 234
[2023-03-09 15:11:37] |
User652903 - Posts: 19 |
Yesterday all of my OCO orders started flashing this error. I do not know why as the OCOs were working fine before. The orders are still being cancelled but I am being blinded by the constant error message. Can you please advise why this is happening?
Private File |
[2023-03-09 17:05:37] |
Sierra_Chart Engineering - Posts: 14092 |
Are you using the Flatten command or Cancel All?
[2023-03-09 17:10:08] |
I'm using Flatten with the option toggled to Cancel all upon Flatten, but I think this is not relevant, since the error message is popping up even when my OCO stop or target is hit on its own.
[2023-03-10 18:04:34] |
You can safely disregard this but we do need to look into why this is happening. It should not be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
