Date/Time: Tue, 30 Apr 2024 09:45:29 +0000
"Hide Chart Drawings" question
View Count: 1560
[2013-05-01 18:38:09] |
joshtrader - Posts: 439 |
I have the "Hide Chart Drawings" command on my Chart Shortcut menu. Currently, it hides ALL drawings. Is there a way to make it hide only user-drawn drawings, and not those drawn using custom study code? I would think so, since ACSIL differentiates between user-drawn and non-user-drawn drawings with UseTool.
[2013-05-01 21:17:38] |
Yes, we will correct this. It should not be hiding ACSIL drawings.
