Date/Time: Wed, 08 May 2024 21:23:10 +0000
keyboard shortcuts
View Count: 192
[2023-03-06 19:45:45] |
Ermin Alibasic - Posts: 1 |
i cant use keyboard shortcuts on my chart,my keyboard shortcuts are on,when i try to use my shortcuts wich i made in settings,when i try to use them the leters for shortcuts apear on top of the chart in the name of the chart section.
[2023-03-06 21:57:25] |
John - SC Support - Posts: 31479 |
You can not setup keyboard shortcuts to single keys - such as the 'E' key. As this is a standard input for the letter 'E'. Make sure the keyboard shortcuts you are using are either special keys, or have a modifier (shift, ctrl, alt). The information showing at the top of the chart is correct functioning. This is used to allow you to quickly change the symbol for a chart, or to change the time frame for a chart. Refer to the following for an example: Changing Chart Bars Period: Fast Changing by Keyboard For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
