Date/Time: Sun, 28 Apr 2024 19:14:55 +0000
stop loss
View Count: 195
[2023-03-06 19:07:58] |
SkyKeeper - Posts: 39 |
Hello If I trade with such settings and manually set a limit, then when the limit is triggered, the position and the limit have stop loss orders. How to make sure that stop orders are deleted automatically during liquidation |
sierra1.PNG / V - Attached On 2023-03-06 19:07:47 UTC - Size: 13.77 KB - 49 views |
[2023-03-06 21:38:18] |
We are not quite sure of what you are asking. But, when you place a Limit order with the attached orders as you have them shown in the image, then when the primary Limit order fills, then the Attached Orders are going to be sent to the exchange as Working Orders. Since these are Order-Cancels-Order (OCO) attached orders, then when one fills (Target or Stop), then the other will be canceled (Stop or Target). If you do not trust the system, then be sure to watch carefully the first few trades to make sure everything works as you expect. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
