Date/Time: Fri, 26 Apr 2024 01:24:30 +0000
[Programming Help] - About self-built real-time data
View Count: 205
[2023-03-06 04:10:52] |
User806728 - Posts: 5 |
Can I use python to receive real-time data, then write it into a csv file, read it in real time with Sierra Chart, and then use Interactive Brokers for transactions? If possible, how should it be done? Thanks
[2023-03-07 09:20:50] |
Sierra_Chart Engineering - Posts: 14092 |
The way you would do this is write the data to an Intraday data file. The format is documented here: Intraday Data File Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
