Date/Time: Sun, 05 May 2024 04:29:56 +0000
Add Additional Symbol study - continuous futures
View Count: 251
[2023-03-05 23:00:18] |
User629461 - Posts: 158 |
Hi, I underatand its not possible to show continuous futures chart symbols using Add Additional Symbol study which is a shame. However, is it possible to create a custom symbol, which is derived from continuous futures data, as a way of getting around this problem? |
[2023-03-05 23:04:01] |
Sierra_Chart Engineering - Posts: 14224 |
Yes that will work.
[2023-03-05 23:21:06] |
User90125 - Posts: 715 |
Could Support give an example of how? Thanks. |
[2023-03-05 23:44:48] |
This is for the user to determine. We do not know how they would do this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-05 23:44:58
[2023-03-06 23:51:19] |
Support, to create a custome symbol would I pull up a continuous daily chart with the historical data I am interested in, then export this as a data file, then re-import as a new symbol? Or is there more effieinct way to do this? I assume this file would need to be updated manually or is there a way to do this automatically? Your help's appreciated. Thanks
