Date/Time: Mon, 06 May 2024 19:03:10 +0000
Send drawing to remote SC with ACSIL
View Count: 282
[2023-02-28 08:48:46] |
User785723 - Posts: 57 |
What is the best method to send a drawing to a remote Sierra Chart via ACSIL? Is it possible with UDP? Any specific documentation on this topic? Thanks! |
[2023-02-28 10:48:43] |
Sierra_Chart Engineering - Posts: 14244 |
We would recommend writing the drawing data to a file and then reading it in the other instance of Sierra Chart using the ACSIL file functions.
[2023-03-01 03:36:53] |
Are you suggesting this method for remote or local instance of Sierra? I am interested in transferring the drawings to a remote instance on a different system. Also I wonder how can I make this study as a subscription based service. For that to be done, I need to get the username from the remote instance and allow one/two sessions for each user. Any docs to give hints on these? |
[2023-03-01 08:27:42] |
If you want to transfer Chart Drawings to another installation of Sierra Chart on a different system then you would need a network connection for that. One thing we are developing that is close to being released is real-time Chartbook sharing. So what you want to do is going to be covered in this functionality because this would include the transfer of Chart Drawings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-01 08:29:19
[2023-03-13 02:42:30] |
Great news. Any update on the release date for this feature?
