Date/Time: Fri, 27 Jan 2023 14:58:09 +0000
30 Year Treasury Bond and Ten Year Note
View Count: 981
[2014-06-12 14:47:32] |
Discount - Posts: 73 |
Can you give me the Sierra Data Symbols for the 30 year bond and the Ten year note? Can you also tell me am I getting this data from Sierra Data in my current subscription, or do I need to pay more for this? If I have to pay more, please let me know how much for the 30 year bond and the Ten year individually. Thanks |
[2014-06-12 15:51:38] |
You are using TransAct. You can find the symbols in File >> Find Symbol. The symbols begin with: ZB ZN We see you are using an older version of Sierra Chart. Update with Help >> Download Current Version. Do you see a [M] after the symbol at the top line of the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-12 15:53:27
[2014-06-12 16:11:12] |
Have not done the update yet, but I did find the symbol. On top of my chart it reads SC ZBU4 CBV M so I guess I should be good? Thank you,
[2014-06-12 16:28:46] |
Yes.
