Date/Time: Sat, 04 May 2024 01:08:06 +0000
Futurepath
View Count: 1407
[2014-06-12 14:23:36] |
stephensmart - Posts: 51 |
Hi, I trade es futures through futurepath and clear through Vision Financial Markets, is there a link up with sierra or if i want to view es data on the charts will i be charged $35/mnth for the data? Is breadth data like tick ($tick, code i think) included? |
[2014-06-12 16:43:34] |
Vision uses Rithmic. Therefore, you can use the Rithmic trading platform service from Future Path with Sierra Chart. Refer here for instructions: http://www.sierrachart.com/?l=doc/Rithmic.php Market statistics data is included with Sierra Chart package 3 and 5. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-13 06:45:47] |
I would prefer to use the sierra data, if i subscribe to cme emini data is that $35/mnth and does that include live market statistics data?
[2014-06-13 07:07:55] |
If you want to use the Sierra Chart Data feed for CME data, you need to be connected to a supported trading service. This is explained here: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-16 06:21:35] |
To answer your question about market statistics data , the market statistics data is provided with Sierra Chart packages 3 and 5. This is separate from the Sierra Chart Exchange Data Feed.
