Date/Time: Sat, 04 May 2024 12:47:01 +0000
Spread charts using OEC for data
View Count: 1371
[2014-06-12 13:32:37] |
User99278 - Posts: 2 |
How should I format the symbol for future calender spreads? Im using OEC for data? |
[2014-06-12 15:42:54] |
How is the spread symbol specified within the OEC trading software itself?
[2014-06-12 15:48:03] |
this is a feeder cattle spread I trade GF FTS +Q4,-V4 |
[2014-06-13 04:30:54] |
This is going to take research time. Please allow one week for us to look into this. No one has asked us about futures spreads when using OEC before and we have to see how best to handle these. You could just try using that symbol as is in Sierra Chart. Select File >> Find Symbol and into that symbol into the Selected Symbol box. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-13 04:31:32
[2014-06-18 03:09:54] |
In the next release of Sierra Chart coming out in about one or two days, spread symbols will be supported when using OEC. You will need to look up the spread symbols through the OEC trading software. You can use the symbol just like this in Sierra Chart: GF FTS +Q4,-V4 We do not yet have implemented requesting of the tick size for spreads, so you will have to manually set that through Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
