Date/Time: Fri, 27 Jan 2023 14:34:56 +0000
Number of trades to volume ratio
View Count: 1041
[2014-06-12 04:01:11] |
Dom7364 - Posts: 254 |
What would be the easier way to add a study that would calculate the Number of trades to volume ratio? Many thanks Regards |
[2014-06-12 11:40:51] |
Zosimus - Posts: 344 |
The Numbers Bars Calculated Values study has a Subgraph that shows the Average Volume per trade. (Volume/Trades). SG15. http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#SubgraphDescriptions |
[2014-06-12 11:51:05] |
Hi Yon! Thanks, but I am looking form soemthing slightly different: total number of trades for a bar, to volume. In fact I have done it using the Strudy subgraph ration study, and used the Open interest and the volume.. :-) Cheers |
[2014-06-12 16:56:03] |
You need to use the following studies: Number of Trades Volume Study Subgraphs Ratio Refer to this page for documentation: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s236 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
