Date/Time: Fri, 13 Nov 2026 20:48:34 +0000
Custom symbols - blank screen
View Count: 797
| [2023-02-17 13:58:18] |
| Nkrastins - Posts: 38 |
Hello, I tried to create a custom symbol from AAPL/MSFT/AMZN/TSLA/NVDA/GOOG/META But I am getting blank screen. I did download all the separate symbol data prior. It says "historical data download skipped" and then its just blank screen. |
| [2023-02-17 14:03:41] |
Note, I created symbol like this {AAPL}+{MSFT} etc... or should be like this {AAPL-NQTV}+{MSFT-NQTV}? Maybe that's why it doesn't recognize? |
| [2023-02-17 16:14:46] |
| John - SC Support - Posts: 48527 |
You need to use the second format you mention ({AAPL-NQTV} + {MSFT-NQTV} +...).
| [2023-02-17 16:17:16] |
| Sierra_Chart Engineering - Posts: 25422 |
Use -NQTV: or should be like this
{AAPL-NQTV}+{MSFT-NQTV}? Also be aware of: Custom Calculated Symbols: Resolving Missing Historical Data Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-17 16:17:21
| [2023-02-17 16:46:01] |
Yeah, figured this out. Amazing feature btw! |
