Date/Time: Mon, 29 Apr 2024 16:51:27 +0000
Global settings??
View Count: 1001
[2014-06-11 15:32:25] |
TLaw - Posts: 5 |
Hello guys i tried to find this out on my own and couldnt so i figured id just ask as its probably something ive just overlooked and was right in front of my face all along. I was wondering if there was a way to set up my charts so that when i draw a line on one chart or have the crosshairs up on say a daily chart then it would also show those same cross hairs and or lines ive drawn on the 60 min and 10 min charts?? Ive seen this option on other platforms but have not found it on sierra yet. please help. thank you for your time and have a great day. TLaw |
[2014-06-11 15:40:20] |
vegasfoster - Posts: 444 |
Only way I know is F5>>Advanced Settings 2>>Copy Chart Drawings From Chart #'s http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#CopyChartDrawingsfromChart
[2014-06-11 16:48:32] |
There are two features you are interested in. They are documented here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#GlobalCursor (Global Cursor) http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#CopyChartDrawingsfromChart (Copy Chart Drawings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
