Date/Time: Wed, 01 May 2024 19:20:36 +0000
Why different icon but the same version
View Count: 935
[2014-06-11 14:28:41] |
User17064 - Posts: 70 |
Hi SC support, I have 2 laptops and both of them has installed Sierra Chart.Last week, I update to 1137 version. But in one laptop,its find symbol,open chart button has shows like pic. But another laptop, these 2 buttons shows test button. Please find the attachment. What's the problem for this? How can I fix it? |
Capture.JPG / V - Attached On 2014-06-11 14:28:07 UTC - Size: 49.64 KB - 332 views capture1.JPG / V - Attached On 2014-06-11 14:28:19 UTC - Size: 29.43 KB - 357 views Attachment Deleted. |
[2014-06-11 16:21:38] |
The option which controls this is Global Settings >> General Settings >> General 2 >> Use Icons for ToolBar Buttons. You need to restart Sierra Chart after changing this option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-12 06:59:19
[2014-06-12 06:57:44] |
Hi SC support, Thanks a lot for your help. |
