Date/Time: Mon, 29 Apr 2024 09:04:52 +0000
Commission
View Count: 955
[2014-06-10 15:17:51] |
User59482 - Posts: 14 |
Since I did the symbols list update that was sent, I seem to be unable to enter my commission rate in the Global Settings, Symbols Settings, Additional field?
[2014-06-10 16:34:55] |
We are not seeing a problem with this. What you need to do is select a symbol in the list of Symbols on the left of the Global Settings >> Symbol Settings window. Select the Additional tab and in the Commission box enter the commission value. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
