Date/Time: Fri, 10 May 2024 18:18:39 +0000
Usage Time Expired
View Count: 302
[2023-02-10 19:04:48] |
bratu - Posts: 1 |
Hi, i have a question... To use an Apex funded evaluation account, do I need to have my account activated? I thought that if I connect through Rithmic I don’t have to pay anything. It seems pretty obvious, but i would like to know. Thank you very much! |
[2023-02-10 22:08:05] |
John - SC Support - Posts: 31530 |
Although you can continue to use Sierra Chart without an active subscription (no Usage Time - or what we call "Free Mode"), you have limited capabilities and in particular, you are not able to bring in any new data or connect to any external services. Basically, you can only play with the data you already have in Replay Mode. Therefore, in order to use Sierra Chart with your Apex account, you need to have an active account and it will need to be on one of the Integrated packages in order to connect to Rithmic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
