Date/Time: Tue, 07 May 2024 19:40:16 +0000
Start date-time parameter
View Count: 929
[2014-06-10 06:40:11] |
User14443 - Posts: 6 |
Hi, It would be very nice to have a Start Date-Time parameter for each and every oscillator and indicator, just like in VWAP. Most people don't realize that when using Bollinger bands, RsI, and so on (you name it) you can't specify a starting point for the calculation... On the contrary, each and every profiler knows that it is something crucial. Thanks a lot for your attention. Regards, Ralph. |
[2014-06-10 06:49:36] |
This can be done through Chart >> Chart Settings. You can adjust the first date to load and the Session Times. You can then overlay the study on other charts. Refer to help topic 28: http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-10 07:17:36] |
Thanks a lot ;-)
