Date/Time: Mon, 29 Apr 2024 14:23:10 +0000
Scanning feature request- endless loop
View Count: 999
[2014-06-09 13:02:48] |
Joe Hobart - Posts: 89 |
Ive incorporated some longer term charts and wanted to run another instance of SC that just slowly rolls through a hundred symbols or so as an engagement/ 'a-ha' tool. However, the inability to have it loop till cancelled makes it difficult to implement. Is there a way to give us an option to loop a scan until cancelled? I would also be willing to code an ascil loop, but i wasn't able to find the right function exposing the 'next symbol in associated watchlist' functionality |
[2014-06-09 18:30:03] |
This is not supported. In ACSIL it is possible to change the symbol of a chart and you can program a symbol list into the study function. In ACSIL there currently is not a way to access the watchlist of symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
