Date/Time: Fri, 03 May 2024 03:01:08 +0000
Value Area Extension Lines Extended indefinitely
View Count: 1315
[2014-06-07 13:51:15] |
OneMoreTick - Posts: 79 |
Is it possible to extend value area extension lines indefinitely? I have them set to extend to end of window, but once I scroll to the right and the volume profile is no longer visible, the extensions disappear.
[2014-06-10 10:18:16] |
You can only extend the Value Area extension lines forward beyond the end of the window or Volume Profile period, if you have them set to "Until Future Intersection".
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-10 10:18:57
