Date/Time: Wed, 17 Dec 2025 07:05:22 +0000
What is the corrrect symbol for
View Count: 447
[2023-01-30 17:23:54]
User360283 - Posts: 524
the ES Mini not Micro
using AMP and CME
thanks
[2023-01-30 22:06:38]
John - SC Support - Posts: 43500
The symbol you use depends on the Trading Service you are using. When Sierra Chart is setup to connect to your trading service, then the symbols are setup based on that information. Therefore, go to File >> Find Symbol and open the section for the Futures - CME and look for the particular instrument you are looking for in that list.
