Date/Time: Sun, 13 Jul 2025 07:20:56 +0000
Tried to trade on my live account but it defaults back to Sim
View Count: 574
[2023-01-30 15:24:31] |
User522279 - Posts: 1 |
Hi, I tried to place an order on my actual Dorman account but when I pull the trigger it defaults to simulated trading. I turned of Trade simulation trading and my live trading account shows up. Its been awhile since I last traded on this account but it is active. Please help. Thanks. |
[2023-01-30 15:28:50] |
Sierra_Chart Engineering - Posts: 20186 |
Is your account directly with Dorman or through an introducing broker? Do you know if they set you up on Teton order routing? Here are the instructions for Teton order routing: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-31 03:37:46
[2023-01-31 03:37:57] |
Prior post updated.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-31 03:38:10
