Date/Time: Tue, 07 May 2024 21:18:22 +0000
Z order
View Count: 1044
[2014-06-06 14:21:41] |
darkpool - Posts: 39 |
Hi Sierra, Is there a way to bring certain drawing objects forward (ie: change their Z order)? For example in the attached image I have daily volume profiles. I have colored the candles black so that all you see is the volume profiles. The problem comes when I need to define a certain zone using a rectangle, the rectangle is placed behind the candles. Is there any way to specify that the rectangle should be in front of the candles? Or if that's not possible, is there a way to specify that the candles should be transparent instead of black? |
Capture.PNG / V - Attached On 2014-06-06 14:20:52 UTC - Size: 79.09 KB - 338 views |
[2014-06-06 17:26:19] |
Refer to: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
