Date/Time: Mon, 29 Apr 2024 11:37:14 +0000
update interval non-.net versions
View Count: 963
[2014-06-06 13:31:21] |
User51760 - Posts: 108 |
Hello Support Team, are the update intervals for the non-.net versions of SC alike those of the .net version? Meaning: Do both versions provide the same functionality same time? Thank you for your answer, Best, Chris |
[2014-06-06 16:33:53] |
Yes. Make sure you have disabled Global Settings >> General Settings >> Use Control Order Chart Updating.. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
