Date/Time: Tue, 15 Jul 2025 19:28:31 +0000
Numbers Bars: Text only displays at some prices with Volume Profile Setting.
View Count: 373
[2023-01-29 18:35:15]
User708541 - Posts: 144
With numbers bars, Background type set to Full Background, I see all the text at each price. When I make a single change to: Background type set to Volume Profile, I lose the text at areas with low volume. I've enclosed an image showing exactly what it happening.
I'd like to have the text displayed at all prices regardless of the volume.
Thanks for helping me with this issue.
imageNumbers Bars Text Question.png / V - Attached On 2023-01-29 18:33:21 UTC - Size: 214.98 KB - 146 views
[2023-01-30 17:10:16]
John - SC Support - Posts: 40908
The reason you are not able to see that text is because you have the color for that text to be "Black", the same as your background, so you can not see it. Change your Text Coloring so you do not use a Black (or very dark) coloring.
