Date/Time: Fri, 18 Jul 2025 23:00:24 +0000
Increase the DATES-MINUTES-SECONDS
View Count: 559
[2023-01-28 01:01:54]
User655723 - Posts: 1
When I select the bar period (volume per bar), how can I increase the DATES-MINUTES-SECONDS?
It shows max 2147483647.
Please have a look at the attached picture.
Private File
[2023-01-30 14:59:16]
John - SC Support - Posts: 40963
You can not increase that number beyond that value as that is the limit of the variable that holds that information.
You would need to use the Chart >> Chart Settings >> Symbol >> Volume and Open Interest Multiplier and set it to a value less than 1 in order to allow the system to handle these very large volumes. Refer to the following for this setting:
Chart Settings: Volume and Open Interest Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
Also refer to the following for more information on how to handle these large volumes for Cryptocurrencies:
Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols
[2023-01-30 15:53:48]
Sierra_Chart Engineering - Posts: 20254
We will see if we can allow a larger number to the value of an unsigned 4 byte integer.
[2023-01-31 13:03:19]
In the current release you can use the full size of a 4 byte integer which is 4294967295.
Date Time Of Last Edit: 2023-01-31 13:03:48
