Date/Time: Fri, 03 May 2024 10:59:02 +0000
keyboard shortcuts for exiting 1/2 of position
View Count: 1086
[2014-06-06 07:43:45] |
User85195 - Posts: 60 |
order entry with SC really is easy, Attached Orders work beautifully. but exit is a bit more complicated, esp. if you trade multiple positions. I often found myself in need of exiting half of my positions real fast, at market price, and at the same time move stoploss to breakeven on the remainder. it'd be great if there is an existing keyboard shortcut for doing this. if not, is it possible for me to set it up myself? are there any instructions? best regards |
[2014-06-10 10:19:29] |
For help with trading related keyboard shortcuts, refer to: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
