Date/Time: Sun, 28 Apr 2024 19:54:25 +0000
No Intraday History for Sept Bund Eurex TT/Amp
View Count: 934
[2014-06-06 06:36:53] |
Paul.M - Posts: 113 |
No Intraday History for Sept Bund Eurex TT/Amp the old contract is fine - the new contract not. (I informed Amp too) Date Time Of Last Edit: 2014-06-06 06:50:03
[2014-06-06 08:26:47] |
Checking on this.
[2014-06-06 08:48:23] |
We see historical Intraday data: http://www.sierrachart.com/image.php?l=1402044454781.png Go to the chart and select Edit >> Delete All Data and Download . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-06 09:35:52] |
TY , I did this now Edit >> Delete All Data and Download all is fine now. (The earlier error shows up in my log - if you need it. Otherwise issue solved :) |
